Adding cleats to an internal halyard mast????
22
ODay 240 Lake Nockamixon
What is the best, or smartest way to add cleats to an internal halyard mast?
None of our other boats had any internal ropes or halyards. I would think the main concern with using screws to attach the cleat is that the end of the screws could snag and ruin the internal ropes.
Are stainless rivits strong enough?
I think I would like to add two cleats to the mast and one to the boom.
Thanks for the input. I forgot about thread cutting screws. I have used them in another, unrelated project with aluminum, and they seem to work fine. Unlike self-tapping screws, I will have to drill a pilot hole, but they don't have that sharp, projecting point like a self-tapping screw. I only want to use these cleats for "parking" lines when not in use.
TLW
Jan 15, 2013
271
Oday 31 Whitehall, MI
Yes, drill & tap. SS rivets plenty strong, but don't fit most cleat openings very well. You can use SS self-tapping screws as you mentioned, if you back them back out and clip them off after self-tapping.
Mar 26, 2011
4,042
Corsair F-24 MK I Deale, MD
Whether you can tap is going to depend on wall thickness. If it is < 1/8-inch, as I suspect it is, tapping won't be very dependable without backing nuts and washers. This can be a tough problem.
