Adding Batteries & Inverter
91
Catalina 30 MKIII Mantoloking Shores NJ
We are the proud new owners of a 1995 Catalina 30 MK III. I am looking to add AC power while underway as well as some additional batteries. I currently have 2 Group 27's. Looking to move up to G31's, possibly 4. has anyone done this (sure you have) and can you give me some idea of how it is done. Thanks Hal
Jun 4, 2004
189
Catalina 30mkIII Elk Rapids, MI.
Batteries
Hi Hal; Congrats, you have a great boat! We have a MKIII also, and here is how mine is set up. In the battery box under the starboard settee, I have a Group 27 Dual Purpose flooded in position #2 for a starting battery. Next to it in Position #1 is a Group 31 Flooded for the house bank (105AH) It is wired in parallal with another Group 31 Flooded that is on a platform right next to the water heater next under the rear berth. It is a relativly short run. My inverter (1000 Watts) is wired to that battery with a 250 amp fuse in the positive line. It inverter is mounted against the bulkhead right behind the steps to the cockpit, again a short run to the battery under the settee, which is wired to the other "house" battery. that is Positive to Positive and Negative to Negative. I used #2 Ancor tinned battery cable for both connections. When we need to use the inverter, a 3 ft cord power strip sits on the counter right next to the companionway and all connection are made to that power strip. to me, this is easier and safer than wiring it into the boats AC circuit. The only cost was the cables to the battery. The only thing I had to do to make a group 27 and 31 fit in the regular battery compartment is to cut the handles off the battery boxes that I set them in, and they fit just fine. fair winds Dave
Read the West Marine catalog
or online, they have great descriptions. Or Google "adding batteries to boats" You might also consider buying or going to the library to obtain a book, many have been written about just your question. The thing is that this is a looong subject to answer with your question. Involves wiring, sizing, configuration, etc. Try this link, as the electrical systems on C30s and C34s are very similar.
