Does anyone have a diagram on how to add a third battery to an existing two battery bank? I have an idea on how to do it but would like a second opinion.
My existing set up is (standard set up) one alternator, battery switch (1-both-2), 2 output battery charger. I did not see a battery combiner anywhere.
If I need to upgrade to a 3 output charger that is fine but would prefer to use my existing charger.
My use for third battery is to dedicate it to a amp and sub-woofer also adding an electric head drawing 20 amps per flush.
However I want the option to switch into existing battery bank if needed for starting in an emergency. Thanks for any input.
