Not sure what type you're interested in, but I recently went online and purchased a "floor model" ac (only) unit (6700btu) that runs off shore power only and exhausts both hot air and moisture (no drip pan) from the cabin of my C30. It's mounted beside the companionway steps and mostly out of the way, altho quarterberth access is a little less convenient. Chose to make-up a new lower hatch board with a 5.25" circular hole for the exhaust tube. Delivered price was a bit over $300. Works well in 90+ heat in East Carolina. If interested I can dig up the site and spec info.I put a 12,000 BTU in my Hunter 31, so I would think that would do for your C30.
Decide which brand you want, then go on line and get the install manual, read and reread it, before purchasing and installing. Decide where you want to install it, etc, then purchase the unit.
bill
