hey all;
I will be running pex after the water pump to a three way pex tee, then to a pex shut off valve to the hot water intake via a pex to npt female, and not touching the pb outflow from the hot water tank.
from the other side of the tee i'll run pex to a male npt and tie into the pb again..
this'll work right?
then for winterization i just turn the valve off to bypass the tank..?
cheers
this'll work right?
cheers
