Rewiring / adding circuits in 115 AC power on a boat can be straight forward IF you were experienced in the process of selecting the correct type and gauge of wire, making connections at the panel, and wiring each new plug properly per ABYC specs.
You could study the info provided by R Granger and still not know the issues that may arise in the install process on your specific boat.
House wiring connections/systems are not the same as on a marine set up.
Certainly read all you can find including a book by Don Casey on the subject, BUT...
If you proceed, at the first "wonder how I'm supposed to do,,,?" question, STOP!
Call an experienced marine electrician and get help. At the very least, have them check the system before you power it up.
