I want to add winches and tracks to my Oday 222 in order to fly a symmetrical spinnaker. The attached pictures are of another Oday 222 port side spinnaker set up (winch forward from track). For size reference the winch in the picture is approximately 3.25 inches high, base diameter 3.75 inches , and standard sheet of paper is 8 inches by 11 inches.
I am looking for advice on the best Spinnaker setup for my Oday 222. Does the setup in the pictures look correct? I have a set of refurbished Barlow 16 winches that (if my homework is correct) should be right size. I have not yet purchased track or blocks. Do you have advice on where to mount winch, track ? Should I use a cleat as in the picture, or would other hardware be a better choice?? What track and block shall I purchase? Regarding winch angle: What is the best angle between base axis of winch to sheet entering the winch drum? Thanks Mich 222
