I recently upgraded to a Raritan Sea Era freshwater flush with bluetooth control and I'm actually noticing more head odor since I made the upgrade.  I think the source of the odor may be gases escaping back through the bowl so I added water to the bowl thinking that it may stop the gases, but found the water drained to the holding tank fairly quickly.  My toilet discharge is pretty close to the same level as the holding tank input and the discharge hose is mostly flat. I reached out to Raritan and they suggested adding a vented loop to the discharge line which I'm considering.
Question: Is it better to keep water in the bowl or to flush to dry? Currently I flush to dry, but it seems like it's creating a direct open air path to the holding tank allowing odors to escape. Would adding a vented loop correct this?
