I have a 1987 Oday 222- as shown in the pictures below. The 222s came from the factory without a traveler. In order to rig the mainsheet, a fiddle block is attached to the triangular metal plate in the backstay (figure 14) and connects to a mainsheet block mounted aft on the boom (figure 13).
I would like to add a traveler and have the option of not using that darn triangle metal plate assembly.Others on this site have added travelers, either at the Bridgedeck (added at step from cockpit sole into cabin), or further aft at about the halfway distance across the cockpit seating.
My problem is I don’t want a traveler in the cockpit area or bridgedeck. I like to race, but also like a boat for cocktails and happy hour and don’t want casual boating guests to be forced to navigate a cockpit traveler and have a tripping hazard.
That leaves two positions.
1) I could add a traveler on the transom- and perhaps that is the best option?
2) Is there an option to add a traveler on the cabin top? If so, where would it be positioned?
a. If it were forward of the open hatch, it would be most convenient, however, this position would be very close to the gooseneck – so probably not a worthwhile option.
b. If the traveler was positioned on the cabin-top just forward of the pen boards, it would allow for the longest port- to-starboard track and be nearest to mid-boom sheeting. If this location were chosen I would mount the traveler on a bridge to allow access to the cabin.
If go with option 2b), Would it also be an option to mount the traveler bridge, so that one could remove the attachment to the cabin-top on one of the sides and then pivot traveler out of the way of the access to the cabin. For example, remove the starboard bridge-to-cabin-top mounting, and pivot the traveler out of the opening of the sliding hatch toward port side , so have clear access to the cabin? If I were to use this option, I would revert to the original setup (would use the original triangle/backstay sheeting in times of recreational sailing with landlubbers).
Thanks in advance for your advice.
Mich222
Mich222
