Hello forum friends!
I would like to add midship cleats to both side-decks of my Vision 32 to aid in docking, especially solo, since I don't have a lot of room for error in my 34' slip. From a physics standpoint, based upon what I have researched in other forums, I understand the cleat should be positioned perhaps just aft of the midship stanchion, such that taking up tension on a fairly led spring line upon entering the slip acts to kick the stern in towards the dock, it anything, rather than pulling the bow in. The problem, of course, is access. To properly mount a through-bolted, backed, sealed cleat on the side-deck means being able to access the underside of the deck, but on V32s (and other Hunters, I imagine), there is a molded fiberglass liner in the way, with varying degrees of dead space between it and the deck, depending on where you knock on the liner. A PO installed (properly) a low profile windlass on the foredeck, and hole-sawed through the molded headliner to back those bolts with giant washers, so I know it's possible. I'm just wondering if anyone else has undertaken this specific project before, and can offer some advice?
Many thanks!
-Kevin (S/V Endolyne, Seattle)
Many thanks!
