Cockpit Controls
You'll want slugs on your mains'l. I prefer a good downhaul system with a hanked-on jib but RF might be better for you. Main halyard aft to the cockpit; you might need a longer one. A block at the base of the mast and the starboard stanchion base. A rope clutch might work better for you than a cleat.You can get your sheets aft to the helm with a cam-cleat on the coaming top.I carry a small folding anchor in the cockpit. You can probably put one in the lazarette, or on a stern rail if you have one. Run your anchor line forward, outside the shrouds, thru a forward cleat, back to the cockpit, and cleated off. If you need to anchor, drop it over the side, and you have 25' of anchor line out. You can adjust the length from the cockpit.
