I concur on the choice of polycarbonate. Why use acrylic when the ports are a known weak point on the Vega. I used 1/4" but did a very labor extensive rebuild changing from the two large ports to four smaller ports. Having
seen Chuck and Laura's ports it was a lot less costly and certainly eliminated that inherent weakness. WaltFrom:
AlbinVega@yahoogroups.com AlbinVega@yahoogroups.com on behalf of Gordon gazuum@... [AlbinVega]
Sent: Monday, March 26, 2018 10:28 AM
To:
Subject: Re: [AlbinVega] Re: Acrylic windows
This message is eligible for Automatic Cleanup! (
AlbinVega@yahoogroups.com)
Add cleanup rule |
More info
I'm thinking non colored also after debating myself for a while. Where I came up with acrylic is here.
Let’s start with a tip. Kits sold in auto stores for polishing headlamps can also restore the clarity to portlights. If your plastic portlights are cloudy, not crazed, this is where you should start.
www.sailmagazine.com
I think I'm going to make some phone calls.
Thanks
GordonOn 3/26/2018 10:17 AM, Chuck and Laura Rose
chuck@... [AlbinVega] wrote:
