Blair Dehuff
For C350 sailors on lakes and rivers (or coastal cruisers who rarely go outside the 3 mile limit), or for those who just don't feel right dumping overboard, the following may be of interest if you want to minimize too frequent pumpouts. The diagnosis by Snake River Electronics of the C350's non-linear waste tank monitor readings is as follows. Initially, the manufacturer advised me that additional foil strips applied in an alternate configuration would be the solution. However, they tried this and it didn't work. They now propose to cut off the bottom 3 inches of each foil strip in order to make the tank readings more linear. This also requires relocating the electrical connections on each strip, which are currently at the bottom of the strips.I plan to try this and will advise here if this rectifies the inaccurate tank readings. Snake River says that a conservative first cut of 3 inches should help. However, if it doesn't, Snake River advises to gradually keep cutting off more foil until you are satisfied with the accuracy. Sounds like they are only guessing what's going to happen. The tank is such an odd shape, it's hard to tell.Whatever the result, the waste tank readings can't end up being much more useless than they are now. It might even help. The only other alternative is continued taping on the tank (which is at least a bit more accurate than the gauge). Or, tear out the existing tank entirely and put in a clear plastic one where you can actually see the level (but good luck finding the right size/configuration tank).
