I'm in Guaymas, Mexico and am just about ready to head out cruising. I just checked the LED anchor and incandescent steaming lights and found that neither of them work. They share a common ground and there's power at the base, but I don't see any resistance between ground and + through the steaming light. Atop the mast I checked the incandescent bulb and found the filament to be intact and no corrosion on the contacts.
The connections to the power cable are under the mast head cap and there's no way to access them without removing the mast head, which I can't do with me suspended from the halyard. Does anyone have any great ideas as how I can work on the wiring short of bringing in a crane from somewhere?
-- Geoff
-- Geoff
