access to master bathroom head sanitary tank
O
Olivier
Does anyone know what is the best / quikest way to access the waste tank of the master bathroom (backroom) head? I need to change the hoses. I believe the tank is on starboard somewhere to the right of the head but it is not visible from the engine room... Thanks
Tom
Head Mistriss
I do not have your model boat, however I just finished replacing the hoses on my 34. Before you start check out the website called "Head Mistress". She has some great tips for easily removing and snaking the hoses through the boat. I could have saved myself about 4 hours of time, a lot of grunting, and several strained muscles if I had checked out the site before I started instead of half way through the project.
STEPHEN RODES
MASTER BATHROOM HEAD TANK
The tank is located behind the bulkhead next to the head. On my 1982 there is a small, wood access door just aft of the head. You can access the hoses from there.
john
Aft holding tank access oday 37
On my 0day 37 the holding tank was cracked at the lower waste outlet. The only way to remove the tank is to cut a rather large access opening in the starbord interior gel coat glass bulkhead which is to the right of the head and to the left of the sink as you look from the door. This is just below the shelved area. Good luck Johnfryer@yahoo.com
