Fuel Line
Tim,I just purchased a used C22. The previous owner had cut a small notch in the frame below the cockpit seat, large enough to accept the fuel hose, it is then routed in the groove of the seat and frame into the cockpit area and over the stern to the motor. Seems to work okay and allows me to easily and quickly connect/disconnect the fuel tank from the motor. Hope this helps.
