My mast lights are inop (anchor, box and deck lights). I had the lights replaced and rewired after a lightening hit. However, my electrician says that I am not getting negative feed to the lights. The mast light connection is inside the mast (28 Catalina)...and does not have (currently) a mast access panel. One option is to lift the mast up and reconnect the wire connector....expensive. I was wondering is it possible to remove the compression pole inside the cabin (temporarily) to access the wiring harness and fix.
