C
Chris Callaghan
Trying to get to the bottom of the oil pan is a pain, so I've decided to install an access panel thru the bilge. Using a hobie cat twist access plate, 4 1/2", I plan to drill thru the slanted fiberglass. I realized that I must make 2 holes as that p to s strut is hollow, about 2' thick. I called Catalina and they said it was not a bearing wall type of situation. Has anybody else done this, and what did you use? Thanks for any input.
