Consider how you will charge your batteries
I took delivery on a new 410 in April. After several months I can see I forgot to add one very important component. Depending on your cruising aspirations, if they include staying overnight at a mooring, you should consider how you will keep your batteries charged. The alternatives are generator, solar or wind generator. Generators are probably the best to have, but they are expensive. On my boat, it would have cost over $11500 from the factory. I just got a quote from a Fisher Panda dealer of $20000! Whatever you decide upon, will be easier to swallow over the life of your loan, rather that by a credit card.Other items you should consider are an inverter, increased size of your house battery banks and a anchor that is capable of handling your boat in heavy weather. I needed to hire a metal fabricator to design and weld a bracket for a small outboard motor on the starboard side aft seat rail. Hunters don't come with a suitable place to bolt one on. A radar/chartplotter makes life a lot easier.John Richards/v Jack's PlaceMy boat had an electric winch in the cockpit. So far, it has been a life saver.
