Acceptable methods for connecting three or more wires
Sep 24, 2018
4,524
Catalina 30 MKIII Chicago
I'm interested in high quality connectors for two scenarios; The first for general connection of three or more wires and the second for tapping wires. I have the HST-Pro crimpers and am not opposed to buying more. While I have a Hakko soldering station, I'd prefer to find a tap connector. It's a bit more practical on a mooring.
Sep 24, 2018
4,524
I love Wago connectors but they aren't appropriate for all applications. The one that comes to mind is the bilge pump.
As for a tap/splice, Schotchlocks would be ideal if it was more reliable. TE Connectivity has their own version but I'm guessing it's the same overall design on the inside. I'm planning on installing a wireless relay system to turn various circuits of my electrical panel on/off. The relays essentially bypassing the switch when they are active. It helps keep me at the helm instead of rushing down below. Safety and convenience.
Apr 25, 2024
828
With regards to soldering, I carry a butane soldering iron. It isn't a perfect solution because you also have to carry butane, but it is nice when you need it and there's no shore power. Plus, they are handy for heat shrink tubing.
Likes: Timm R Oday25
Sep 24, 2018
4,524
What would you use to connect three wires together in your bilge?
I have one as well. Butane seems to slowly leak out when not in use so I might switch to a Hakko iron with an inverter
Apr 25, 2024
828
Me, I would solder them together and cover with adhesive-lined shrink tubing. Anywhere I thought I might want to get at the circuit (like to disconnect or expand), I would position that in a less hostile environment.
Yeah, I've noticed that too - something I don't find comforting.
Sep 24, 2018
4,524
I've used the butane soldering iron twice in the past year. My can of butane is already empty. I'm probably going to switch to electric
JBP-PA
Apr 29, 2022
789
Jeanneau Tonic 23 Erie, PA
There are several different ways to connect 3 wires. Practical Sailor says crimping two at a time seems OK.
"A common concern is that a crimp might be compromised if you placed two wires in one fitting, even if they fit properly. We did some testing with a small sample of 14-16 AWG ring-eye connectors and our pull tests met the UL requirement and far exceeded the ABYC requirement."
I've used these. They are cheap, but a pain because they are not insulated.
Sep 24, 2018
4,524
I took a peek behind my panel yesterday and discovered that they used spade splitter connectors on the back of the breakers for many of the connections. There were an average of three switches per breaker. The common bus between the three switches was an uninsulated wire soldered to spade connectors. Even on the AC side there were uninsulated connectors. Some of the decisions Catalina made appall me.
I'll likely end up using more piggyback or splitter connectors for this application. I have some large heatshrink
JamesG161
Feb 14, 2014
8,032
Hunter 430 Waveland, MS
Paint them with Liquid Tape. [3 colors avaiable]
Jim...
PS: Hunter boats did that in tight places.
Sep 24, 2018
4,524
Jim...
Doesn't that present a risk of getting liquid tape into areas of the connector that it shouldnt or gluing two connectors together?
JamesG161
Feb 14, 2014
8,032
buy tiny paint [ toy soldiers type] brushes, use a tiny magnifying glass or give up. :facepalm:
Jim...
Interesting idea Joe. That glue has a low temp threshold until it melts. It might make a total mess in in a space with your engine. There is a reason to use a good glue infused shrink wrap. The glue oozes out and provides a moisture barrier, while the plastic fuses around the wire and connector. The shrink wrap should be heat rated like the wire you are using.
  • Helpful
Likes: JamesG161
Feb 6, 1998
11,760
If you're insured I would advise against solder.Insurers follow ABYC.... If you feel you absolutely must solder, because your crimp tool is low quality, crimp first then add some solder..
