I Used This System
I used this same setup the past two falls, doing the ICW, from the NE back to home base in New Orleans. The numbers given by Bill are correct. I had a unit that drew 1.9 amps, on AC, which converts to roughly 20 amps off the batteries. Traveling the ICW, which after Norfolk is mostly motoring, it is not a problem. I have a three hundred amp hour house bank, and I had no problems with overnight at anchor, but could not make 24 hours without recharging. I watched my usage pretty close, and the little fridge ran about 30%. The small office/dorm fridges are not well insulated enough to do a good job on a boat.
