waeco Link: AC/DC for BD35F compressor
From their site: (Note that the new compressors will run on either 12 or 24 volts... so this works even with a 12 volt system and isolates the compressor.)MOBITRONICMultivoltage rectifier MPS-35(110-240 volts > 24 volts) For problem-free connection to 110- to 240-volt mains systems. Suitable for all COOLMATIC refrigerators and cooling units with Danfoss BD35F compressor. Mains voltage: 100 to 240 volts AC Output voltage: 25 volts DC Output power: 110 watts Battery voltage: 12/24 V Output current: 2.5 A Dimensions (WxHxD): 160 x 55 x 115 mm Weight: approx. 0.7 kg Quality features: switch mode, automatic priority for mains operation Test mark: GS, CE Ref. No. MPS-35
