AC Electrical green wire current?
walt
Jun 1, 2007
3,542
Yep.. and you are correct about mainly being able to see if there is leakage into the water with shore power - because the shore power is definately referenced to the water.
FYI, I when I quickly looked at the OP numbers (below)
Black (power lead) 9.50 Amps
White (common) 9.15 Amps
Green (ground) 0.45 Amps
I had assumed that the current on the white and green (9.15 plus .45) exactly matched the current on the black (9.50)
But.. they dont exactly. The white and green add up to 9.6 amps... There is an unaccounted for 0.1 amp?? If on shore power and no current is leaking into the water, currents on white plus green should equal current on the black. Is this just a resolution error on the meter (ie, resolution is only .1 amp).
Edit to add an interesting thing you brought up. If you put a current meter on a shore power cord (total cord, not individual wires), you can only tell if there is leakage into the water because the net return current will not match the source current. But if the ground fault is internal to the boat, putting the current meter on the the whole shore power cored wont show anything.. because the sum of green and white current will exactly match the black current. Ie, the net current in is still equal net current out so meter doesnt show anything.
2,160
Hunter 40.5 Beaufort, SC
Thanks Everyone for the thoughts. I can't get to the boat for a couple of days to do some of the measurements suggested. I'll post back when I have results.
Likes: JamesG161
JamesG161
Feb 14, 2014
7,821
Hunter 430 Waveland, MS
Test for galvanic issues with your AgCl reference probe.
Using your AgCl reference probe procedure [manual included with Probe],
you can verify you have a working Galvanic Isolator! :cool:
Jim...
PS: Per our Private discussions @smokey73 you may have just found the reason for your excessive Zinc loss! :dancing:
