Denise is right on.. I changed the one in my unit but the failure was a corrosion pinhole thru the case which was not reparable.. Compressor was still fine . I bought the new compressor and had a professional shop replace the compressor because it is silver soldered and I didn't have the appropriate equipment. My old unit has Freon 22 in it.. it is not toxic ... but if you burn it with a torch .. the resulting gas is toxic. I had the shop test, evacuate it, and recharge it .. Works fine again. Final cost wasa little over half the cost of a new 12000 BTU unit. I removed the unit and took it to the shop otherwise, the labor cost would have driven the price to parity with a new unit.
