A Windlass for my 28’
Growl
Oct 11, 2020
109
Hunter 28 2 Alamitos Bay Marina
Has anyone out there installed a manual or electric windlass to their Hunter 28?!
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Looking at the pic, and just imagining the space on the foredeck of a 28', I wouldn't think you could squeeze a windlass in there. I can understand why you might want it, all chain rode, or perhaps ill health or weakness. But it will be tough I think. I'm going to look for small windlasses, just out of curiositty.
Remember, if you put it on deck, it will impinge into the space of the V-berth, unless you can squeeze it into the anchor locker.
What size rode do you have?
jviss
Feb 5, 2004
7,090
You know, you could fabricate a piece to go across the anchor locker, under the cover, and cut a hole in the cover to expose the windlass, so you can operate it with the cover closed. The piece would have to be very strong, and tied well, structurally, into the hull.
Growl
Oct 11, 2020
109
That’s what I was thinking the hinge and latching device being the weakest link
jviss
Feb 5, 2004
7,090
Yes, you don't want to mount a windlass on the cover! As I think about it, on my Tartan 3800, that's how the windlass is mounted. It's on a very thick fiberglass "bridge" that runs across the top rear of the chain locker, and is firmly bolted on the sides to the boat structure.
Jan 7, 2011
6,017
Oday 322 East Chicago, IN
Not a very deep locker, so mounting the windlass below the deck probably won’t let the chain fall. Maybe not even if the windless is mounted on the deck.
Tough to find the space on a 28-footer. My O’Day 322 isn’t much better, and I haven’t found a good way To mount a windlass.
Good luck,
Greg
Jun 21, 2004
3,225
Beneteau 343 Slidell, LA
Had a similar dilemma when I owned a hunter 33.5. It had a shallow anchor locker and to further complicate, no bow roller. Appears that your hunter 28 has the same configuration. I had seen photographs by an owner who fabricated a stainless mounting plate that accommodated a low profile windlass. He also had to modify the locker cover to include the mounting plate & windlass. He incorporated an offset anchor/bow roller on the mount because the forestay attachment interfered. His design was robust & functional, but it appeared like it belonged on a commercial fishing boat and somewhat detracted from the appearance of the sailboat. I never did install a windlass on that boat.
