A Reminder...
Rick D
Jun 14, 2008
7,206
...if you have not already, it's a good time to check the CO2 cylinders and pins on your inflatable life vests and packs. I checked five and all were in good shape except for one that had a dimple in the cylinder. A couple had the green pins sheared off but the trigger had not fired (duh) so I left them alone. Also, check your flares. It's SPRING!
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Also, make very sure the CO2 cartridges are FULLY SEATED. Many will look seated but may not be screwed in enough to work properly.
