H
Hoosier Kevin
I am in the final planning stages of mounting my new bracket - Garelick 71090 - so that I can mount my new 4 stroke 9.9 motor - The problem has been - dealing with the wedge - it is too skinny - and looks to need more backing - - I have reviewed the attached web site - and it looks to make great sense! = Attaching a plate to the wedge - I am thinking of an aluminum or stainless steel plate - but I would add a 3/4" piece of treated plywood also = reverse the bolts on the current mount to attach the new plate - and add the same to inside of the transom for added backing - I also know that I need to consider the cavitation factor - so I need to make sure it is so far down - and I know I need to watch out for the rudder - make sure it is placed so it won't hit the rudder - = Wanted to throw this out to the forum for some needed input - so what do you think? - Thanks!
