a non starter
Oct 2, 2005
465
I motored to the fuel dock today and when I turned the key to
leave, ... silence. I think I may have finally turned the key instead
of shutting off the fuel to kill the engine, but I just don't
remember. If that's what I did, how do I trouble shoot and what is
the fix? Thanks
Craig Tern #1519
Oct 19, 2019
921
Albin Vega 27 Limerick
Hi.
Turning the key off - if wired "normally" - wouldnt have affected the
engine at all..
It certainly wouldnt have stopped it unless you have an electrical
cutoff wired up??
(Instead of the conventional tee-bar that you pull to stop the engine.)
Have you checked that the battery is charged and that the connections to
the starter motor are ok?
A cheap multimeter is your best friend...
John
Vega 1447 Breakaway
vegatern wrote:
Oct 31, 2019
230
Craig, I had similar problems several times this season. Once it turned
out to be one of the battery switches (needed replacement). Another time
it turned out to be corrosion or loose conection on the wiring leading
from the ignition switch to a bus bar. I am not an electrician. I just
diagnosed by trial and error. Good luck. Trev V-2915
________________________________
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On
Behalf Of John Kinsella
Sent: September 18, 2007 5:08 AM
To: AlbinVega@yahoogroups.com
Subject: Re: [AlbinVega] a non starter
Hi.
engine at all..
cutoff wired up??
John
Vega 1447 Breakaway
vegatern wrote:
Oct 2, 2005
465
Played hooky today and went to the boat. Found the problem quickly,
loose connection, but others as well, so now I'm thinking I should
just go ahead and begin a major electrical clean-up. It is something I
have put off for perhaps too long. Thanks for your suggestions.
Craig
