Why?
The recent rescue of the British couple and other have put emergency steering firmly on my radar screen. Like most foam core rudders, mine one gets some water in it that has to be drained out every fall. If the water should penetrate to the weld where the steel plates that transfer the steering torque from the stock to the rudder should fail, the stock could end up turning freely in the rudder. The rudder would still be attached to the boat but the multiple ways I have of turning the rudder stock would still leave me without steering. This simple expedient leaves me with a way of getting lines attached to the rudder that can be taken up around the hull to the winches to provide emergency steering control. It will also be useful when I remove the rudder someday.
The foam core was removed for about half an inch around the hull between the skins with a bend nail in a drill and replaced with epoxy and chopped fiberglass. A threaded PVC pipe nipple was then epoxied into the hole, ground flush, and rounded in the inside corner to protect the emergency steering lines from chafe. For a long offshore passage, I can pre-rig lines and tie them off loosely to the self steering gear mount so that steering lines can be rigged without having to go in the water.
I was relieved to find how dense the foam used in this rudder is when I removed the plug. It's about the consistency of soft pine and was nearly as hard to strip out with the bent nail in the drill. I injected the voids I could find with epoxy using West system fillable caulking gun tubes. Bond between skin and foam appeared solid in all the critical spots even before epoxy injection.
