Hi,
We've bought our 1990 Catalina 30 "De gevleugelde Cat" (The Winged Cat) in march 2014. Last winter we hired someone to make some repairs/additions
(cracks in skin below stanchions, both sites==>Edge cut open over 3 m. both sites and wood chipped out. Filled with epoxy and rebuild the edge;
Rudder was bended==>Cut of the blade of the rudder, straightend the pole, refitted the blade;
new lights in mast;
added windmeter,
replaced macerator,
repaired fresh waterpump and a few things i forget at the moment).
But last weekend we came aboard and found one battery empty. While it was on shore-power. So we decided to replace the two 72 Ah for two 105 Ah. Everything OK. But when we started the engine (Universal m25 XP), the beeping outside by the starting panel doesn't stop when started. And we can't figure out why. Because it isn't so loud and we couldn't find anything, we even continued using the engine for several ours. We checked for: Temperature: is normal like always. We assume oil pressure is still ok. We checked oil-level. Still full. And we do not have any lights on the starting panel (never had, btw. Also not when starting normally).
1. Does anyone have a suggestion? Could it be the alternator gives of a signal because we now have new, larger batteries?
2. I've included a two pictures of the engine. We can't find what the use is of the lever with the hook attached to it. Does anyone know?
3. Shouldn't there be a tube or something like that attached to the little pipe in the middle? Because we think it's there to overflow oil???
And for the last questions: When we came aboard last Saturday, we used the faucet and a terrible rotten egg smell almost overwhelmed us. So we pumped al the "fresh" water out and used Puraclean. We've looked inside the tanks and at least the one on the starboard site is dirty, very dirty on the inside. But there isn't a very big manhole, so cleaning by hand is not possible.
4. How is the foreward freshwatertank connected to the backward?
5. We bought more Cleaner and filled the tanks and used the cleaner. It must stay in for a least 24h, so now we wait. We are planning on tapping it next time and fully rinse the system 2 times at least. Do you think that should do the trick, or should I really remove the tanks and clean them by shaking etc and replace the hoses?
Thanks for your time/answers,
Wouter
new lights in mast;
added windmeter,
replaced macerator,
Wouter
