A Discovered Hull Repair
17
Oday 272LE halifax
Last year's haulout placed my 272 about 6" further forward in the cradle than it was when I bought it, revealing about 4" of previously hidden hull (approximately under the rear bulwark). When I scraped off the old antifouling paint there I discovered about a square inch of hull that had obviously suffered a blow and been repaired with what seems to be grey epoxy filler. The edges of the repair are jagged and there are some hairline cracks in the repair. The repair is well to starboard of the engine mount and hidden by what I think are hull stiffeners connected with the engine area, so it is impossible to see from inside if a repair has been mad with fiberglas, and my guess is that it has not. There is no water infiltrating into the boat, however, and tapping the hull seems to indicate there is something solid above the repair. I would be grateful for comments. Do I put a layer fiberglas on the exterior (a difficult operation), orjust forget it, and go?
Jul 15, 2004
3
- - Halifax
hull repair
Do it right, get to the bottom of the problem. grind it down to good glass, no cracks or miss colouring.then depending on how far down and wide lay in new glass (more than 1 layer?) fill and fair. while water may not be coming in the boat it could be soaking into the fibers of the lay up. the book on repairs by West System is a good place to start if you are not sure of what to do. May be have your yard or surveyor look at it? Good luck Derek
Jun 24, 2004
17
Oday 272LE halifax
Thanks Derek
The thought of radical surgery is always off-putting. But that's the way I'll go. I'll get the West System book. However for this season (three months)I shall clean the wound, put a smear of Epoxy over it, and hope for the best. Thing is that the spot is so close to the cradle support that I will probably have to jack up the boat to find room to feather-in any new glass/gelcoat Thanks again, Samphire
