I posted my problem on this board a while ago and I have just solved it!Problem:Can only get up to 2000 rpm in gear. Lots of white smoke.What didn't work:Changed fuel filters, bled fuel system everywhere. Checked and cleared exhaust riser (not much gunk in there anyway). Water line at the vented loop to the riser was nearly completely clogged - cleaned and replaced. Thermostat was looking ugly - cleaned it up, tested it (the hot water bath test), and reinstalled it.After doing each of those things above, I tested the engine and it would never get above 2000 rpm in gear. I should note that with 2 kids ages 3 and 1.5, I could only get away for a couple of hours on Sundays to do all this work, so it has been about 2 months of working on the boat!What did work:As you may have guessed - it was the most obvious - I had a 1/2 inch poly line wrapped around my prop. My good pal Jim volunteered to jump in and check it out. He unwrapped the line and scraped the barnacles and muscles off the prop and shaft. No dive gear - just a mask. He was in the cold water for about 20 minutes! Needless to say I am extremely happy to have found the problem. But all this work over the last couple of months has taught me a lot about this engine that I'm sure will come in handy for future problems.What happens now:A lot more wash. Surprisingly it didn't go over 2300 rpm in forward and 2400 rpm in reverse. I think I will get more rpms if I'm moving through the water and not doing a static push at the dock...is that correct?Thanks to all who posted suggestions before!-Rob
