A "cracking" noise
8
Hunter 26 trailer
Hi all. I just purchased a 94 Hunter 26. It seems to be in good shape, except I have noticed a noise that sounds like something cracking when I walk around on top of the cabin, around the mast area. It doesn't seem to be any weaker, and there is no visible damage. Is this normal? Should I be concerned?
Mar 31, 2006
37
Hunter H-26 Hayden Lake, ID
My 95 H-26 does not make cracking noises in that area. When I had survey done surveyor carefully checked area around mast and cabin top as he said it was an area where moisture damage was regularly found. Suggest you check with a moisture meter. Best regards, Mike T.
H
h31sailor
cracking
My hunter 30 crack the same way. It basically means water has gotten under the fiberglass and caused the wood and fiberglass to delaminate.
Do a search on sailboat delamination. If the problem isn't too bad the problem can be fixed fairly easily. (Don Casey has written alot about the repair).
Good Luck
