A/C system maintenance
Mar 23, 2023
2
Beneteau Oceanis B331 Lake Texoma
What is the best way to burp an A/C's water input on an Oceanis B331? I thought I knew, but haven't yet been able to successfully accomplish.
Thanks in advance for any suggestions.
Check for a bleed valve in the water line somewhere near the pump. If you have one you can open it while the pump is running until you get a consistent flow of water out of it. Then close it and the water should keep flowing through the system.
Jun 21, 2004
3,055
Beneteau 343 Slidell, LA
In the absence of a bleed valve , you may have to remove the water line from the air conditioner strainer and place the end of a dockside water hose into the water line to blow out any air trapped in the line. Fill the strainer with water before reassembly and that should do it. I have to close the thru Hull fitting while underway, especially sailing, to prevent loss of prime on the air conditioner water pump & lines.
