Glorioso just had its A/C service since the hull was layed up. The factory unit is an Elite Heat Pump. Before service it was blowing air but not cold or hot air. The air handler/compressor is located in the Port Cockpit Locker. When hull number 244 was built the white plywood wall was built so tight that to replace the wall for service it needed to be shaved via saw by about an inch or two. I am pleased to report the unit needed Freon only to return to Mfg. Specs. for both cold and hot air conditioning.
