AC/Inverter
Unless you have an enormous house bank, odds are not very good that you will have enough power to run it for more than a few minutes. You can do the math yourself.
How large is your battery bank in terms of total Ah?
What size AC unit do you want and how much power does it draw to start and then run?
One of our heat pumps rated at 16,000 BTU draws ten amps of 120V AC. It might spike to about 15 amps to start. Our house bank is rated at a total of 480 Ah, with 50% consumable capacity of 240 Ah. Our 2500 watt inverter might start the heat pump and run for a few minutes, but not for long. That is the reason that Hunter installed an 8KW Genset just for the purpose of running the heat pumps while on the hook.
Terry Cox
