The compressor on my reverse cycle a/c unit (King Air 19k btu) won't start. Heat side works fine, but when I switch the selector over to cool and turn down the thermostat all I get is an electrical "click" down there. Blower runs, but no compressor.I'm guessing this is a technical issue and will call for a repair, but thought I'd post here to see if anyone had advice/suggestions on possible cause, tests or repair. I'm medium mechanically inclined, and will try most anything once. Appreciate any suggestions.
