A/B control modlule
C
chet p
After working for 5 weeks straight this past summer cruise i shut down the unit to defrost. After about 2 weeks i went to start up the unit agian and it started but when i returned the following day it was not running and i can't get it to start. I did all the 12v checks making sure that voltage was present at the right points and i did a resistance check of the 4 pins (older unit) on the compessor and do have approx the right resistance. before i invest in a retro fit module or scrap the unit is there a way to check the elect module first. The unit is old ( r12 so i guess it was installed in the 80's) so i'm not sure if it even pays to try to fix it....any ideas thanks
A/B Module
Chet You may want to consider posting this on the A/B board on this 'site, instead of general interest. Or, just call WAECO A/B, they're very helpful. Stu
A
Al Nash
FIX IT
I had a similar problem with my AB control module, circa '86. You can send it to Miller Marine in Jacksonville, FL, for repair, normally costs $90 plus tax and shipping. Their phone is 904-388-3960.
SCOT
A/B MODULE
SEND US THE MODULE AND WE CAN TEST I FOR YOU. WAECO USA 8 HERITAGE PARK RD. CLINTON CT. 06413 BE SHURE TO PUT A NOTE WITH IT ON HOW TO CONTACT YOU DURING THE DAY.
