No real current in Lake Michigan, is there?
But seriously...hull speed is hull speed, regardless of which way the boat is going. Assume for a moment you are anchored in a 4 knot river...what would the knot log read? If you said 4 knots, you are correct. Of course, being anchored, you won't make any headway against the current. However, if you haul the anchor in and throttle up against the current at hull speed, your knot log will read 6 or 7 knots, but you're only making 2-3 knots against the shore. Of course, if you headed down river you'd be doing 10-11 knots against the shore, but again, your knot log will only read 6-7 knots. The boat doesn't know (or care) which way the water is flowing!
