Depend on the acuity of your sense of smell ;-)
New tanks are reasonably priced if you don't need a custom tank. However, it is possible to fix a tank if the damage is not too severe and if you can pull the tank and get it to a repair shop if it needs welding. If it is a fairly standard size and easy to remove I'd opt for replacement if I were you. I'd bite the bullet and replace the hoses if they haven't been done in a while. You can wipe your hoses with a clean wet paper towel and then smell them...that should tell you if they have had their day and it is time for new.Bob
