The mysterious 30G
Search for archives for the article I wrote some time ago about the 30T and 30G. There are only cosmetic differences, in addition to the extendend cabin trunk of the 30T. I wanted a 30T, but ended up with a 30G. Now that I am used to not bumping my head when entering the forward cabin, I'm glad to have a 30G, because I think the lines are far more attractive.We added a Doyle assemetric last year. There is a block above the forestay attachment on the mast, and there was an internal line on our boat, so pulling a halyard through was easy.I purchased the assymetric that preserved the PFHR rating, which means the luff runs to the block mentioned above. If I had it to do again, however, I would buy a sail that went all the way to the masthead, and would install a block near the top of the mast and run the halyard externally, if necessary. I think the assymetric would be more effective downwind with this extra sail area, and with a fractional rig like the 30G/T, the assymetric gets blanketed by the main when running downwind.Hope this helps.
