Just did the same thing...
I have the m25, but with the sherwood pump. If yours is engine driven, the following will help.First, Have Torsen Marine http://www.torresen.com/universal/welcome.htmlfax you an exploded diagram of your pump. Most likely, you won't need an entire kit ($$). Then remove your pump, and disassemble it - pay attention to the order that the parts come off. Then, order the parts that obviously need replacing. Also, maybe a couple of spares since you're already paying the freight. It's a pretty easy job (at least the Sherwood was).Good luck!
