We recently purchased a 1986 Pearson 28-2. The surveyor noted that the port chain-plate needed to be re-bedded. Does anyone know how to remove them to do a thorough job? We tried unbolting the plate from the strut on the hull as well as the deck through-bolts. Nothing budged. Then we noticed that the axis of the chain-plate above deck appears to be 90 degrees to the one below. Could it be made in 2 halves and bolted together through the hull?
Thanks,
Bonky
Thanks,
Bonky
