John
I am mounting a Edson 7' radar mast on my transom with the pad and backing plate and using the u-bolt bracket to secure the mast to the stern rail near the ladder.When I mounted the mast to the stern rail without even putting the radar and top mount on, the rail kind of flops around when the mast is moved manually.How solid does it have to be?Should I move the mast more to the outside where it may be more stable, or should I tighten the rail bolts and leave it where it is?Fortunately I only drilled one hole for the transom plate so it is not a disaster if I have to move it.Thanks - John
