Dan Barrera
I am in the process of buying my first boat, and saw an 85 Catalina 30 which appeared to be in decent shape consdering the age of the boat except for two items. I would really appreciate your comments as it will likely play a big part in whether I ultimately go through with the deal. The owner is asking $28,4001.There is a soft area in the cockpit floor in front of the companionway where it appears that a rectangle shaped area of the cockpit floor has separated from the fiberglass core. It is approximately 2 foot by 1 1/2 feet in dimensions. The owner stated he never noticed it before which causes me even more conceRn because who knows what else he has missed. IS THIS A BIG OR EXPENSIVE REPAIR?2.The diesel has been overhauled and appears in otherwise good condition however I was told that it was reinstalled raised up so that water wouldnt get into the exhaust. As a result, the access panel under the seat cover has been cut out and a plastic panel put in its place it accomodate the higher sitting engine. HAS ANYONE heard of this before? It is a 21 HP Universal. Thanks for your responses.
