'84 H31 Mast Bend Recommendations
Mar 28, 2014
51
Hunter 31 Lake Norman, NC
Have an '84 H31 and the mast has a bend aft. I have a split back stay. Can someone direct me to recommended bend? Thanks in advance! Chuck
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
Choover my '83 has the same aft bend. I'll try and post a picture tomorrow.
Hunter 34 Alameda CA
On these B&R rigs it is referred to as prebend. If you search on that you will see quite a bit of discussion. Your rig needs 1% bend over the length of the mast. For a 50 foot mast that would be .5 feet or 6 inches at the middle confirmed by pulling a string from top to bottom and measuring the deflection in the middle. The diamond stays are what sets the prebend and is usually done with the mast down.
Mar 28, 2014
51
Thank you both! I'm quite sure mine is excessive is 1% is the goal. Can they be tuned without dropping the mast?
Apr 5, 2011
113
Hunter 34 Tilghman Island, Md
If you have a rigger who knows what he's doing? Probably. I've had my rig adjusted while up but, it was a sideways bend not a fore and aft deal.
Brian
pateco
Aug 12, 2014
2,207
Choover,
Below is a picture of my mast showing the bend 1983 H31
