W
Win
I've had a bad engine vibration for the past 2 years. I changed the engine mounts, and cutlass this year hoping to fix the problem. The vibration only happens in forward gear after the engine has been running for awhile, and only from a dead stop(<1 knot). If the boat is moving forwards about 2 knots it never vibrates. If the engine is cold, it never vibrates! Once it stops vibrating it doesn't re-occur until I stop the boat. Pulling away from fuel docks in the wind has been tough!One day I was running at about 2800 and the engine overheated. Dropped back to 2400 and continued on.Next day I flushed the coolant with radiator flush, and fluched it about three more times till the coolant came out clean. It has stopped over heating the vibration problem has gone away. The only thing I can figure is that the motor mounts soften when it gets too hot.About five years ago I had a similiar problem with the overheating. I didn't know what the problem was and went thought the usual hoops. Check the sea water intake line/strainer flow, replaced the impellor(sp?) on the sea water pump, and even replaced the thermostat. The overheating problem didn't go away. I then tore the heat exchanger apart! The heat exchanger core was clean on the sea water side. However the cooling tubes on the fresh water side were coated with a layer of scum. With very little access to the assembly I could only hose out a little bit. After I put the unit back together I used a radiator flush and flushed it several times. The overheating went away!I guess I just want to share my experience with the others that have been having overheating/vibration problems.
