81 hunter30 water pump
Jul 28, 2012
5
hunter 30 indian bay marina, ny
Help!! I just finished refurbishing a 81 hunter 30. Every works well except i have no water pressure at all. where is the water pump on this boat. the water tank is on the starboard side but I cant find the pump. can someone help me out?
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
On my 79 H30 it's under the access panel in the quarter berth....where you sit at the nav station. Lift up the cushion and take off the panel, it should be there.......not unless it was taken out. Btw, my water tank is on port side.
Oct 27, 2011
154
Hunter 1980 Hunter 30 San Diego, Mission Bay
Ditto what Kito said on my 1980. Water tank on port side, water pressure pump under access panel in quarterberth - where all connections to switch panel are. Seems like an odd spot, mixing electrical and water....
kito
Sep 13, 2012
2,011
Not only that, but the weight of the galley plus the water tank on starboard? I wonder what's under his port settee?
Oct 6, 2007
1,172
Hunter H30 1982 Chicago IL
On my '82 H30, the water pump is below the access panel in the bottom of the starboard lazzarette. 30 gallon water tank under the starboard sitee, storage under the port side sitee, two batteries under the port side quarter berth, five gallon holding tank below port side of the V-berth, six gallon water heater below the cockpit. Hunter moved stuff around on an almost annual basis. My owner's manual doesn't match the boat for locations of most of those items.
