This is my second season with the boat and the first time the mast will be removed for winter storage. I am interested in knowing where the connections for the the mast wiring is located. I am assuming that when the mast is being pulled, the connections will be tucked into the mast at the deck level, where I can unplug them. Am I correct at this assumption?Is there anything else I should be checking out at this point?Thanks,Scott
