76Reinell interior retrofit
2
I have a 1976 Reinell 2210! Anyone out there have one of these boats? I have taken the old carpet off the bulkheads and finishing up cleaning the bulk heads of the excess very tough and dry glues used, and it is tough to get off. What I want to do on the inside is paint the bulkheads then place some slats on in the V berth but, nor sure where to start. I have seen pictures of several interiors that have this on the bulkheads and I like the way it looks.
What I am thinking is putting like strips of wood and glue vertically on the bulk head at an equal spacing then I would have studs if you will to attaché the slats to. Does this make since and will it work? Has anyone attempted this type of interior retrofit? Would a good glue work to hold the "studs" in place?
Jul 30, 2012
43
O Day 28 foot Fernandina Beach
Sailingonu,
I striped my ODay 28. Worked well. I looked on line and U tube. Used Liq Nails, 1x2 pine for braceing across the hull and finished with epoxie and glass tabs. I went 14 inches on center and allowed all to dry for 24 hours before takeing braces down. Next shorten the braces and did port side. Working well. Solid attachment. Paint inside hull if going to have space between slats. Is this helpful and clear? Good work, Boatsail1
Dec 14, 2012
2
Sailingonu,
This is very good information, thank you. Do you have any pictures? How did you do the bracing to keep on bulk head not sure if I understand?
